1 - 9 of 9 Posts
I'm getting boost flutter after I installed a fmic last weekend. The car runs perfectly until full throttle at >5000 rpm when I can feel it hesitating and not getting full boost. I checked for leaks with soapy water and found absolutely nothing. I'm leaning towards a bad tcv or a weak cbv spring/deteriorated diaphagm. Any other thoughts or input?
Car is an 04 V70 2.5T fwd with a 16t, 3" turboback and the stock tune. It has fresh plugs, fresh coilpacks, a new pcv system and all new vacuum lines, 144k.
16T is an upgraded turbo for that motor, right? You have a completely new induction, boost, and exhaust system, everything I've read says you really ought to get a new tune. Have you disconnected the battery and let the car try to re-learn the setup?
The tune is the next step, but I had to get all the pieces in place first. The 16t and exhaust have been on for months and I got zero flutter until immediately after installing the ic.
I did think about letting the ecu re-learn, so I pulled the fuses for a couple minutes yesterday. I drove about 20 miles after and the problem was still there, though it seemed to be getting better...but that could just be my imagination.
sent from...
You have enough new parts that the stock tune might never work well at extremes of throttle/RPM/boost/etc...
Agreed,
Now that it's 100 times more efficient, the engine probably can't handle that much air in the most efficient way
True....the fmic and larger piping may just simply have pushed the system past the point of supplying more volume of air than the ecu knows what to do with. I am getting an intermittent overboost code.
Guess I need to expedite that tune!
sent from...
Bumping this back up because I found the problem. Took advantage of ipd's black friday sale and ordered a stock tcv and an ipd hd cbv. I put the tcv on this morning then took it for a drive before I tackled the much more difficult cbv job, and holy s***! Boost is much stronger through the entire range and never falls off....plus I can feel and hear it open the cbv a split second before each shift, so that project is getting put off until I get the tune and need the stronger spring.
I'm very happy overall, this car is getting fast! Even with a ton of wheelspin in first and second gear it hit 60 in about 5.5 according to the stopwatch on my phone.
sent from...
Funny about the TCV's... I installed a Phuzzy tcv the other day, and the motor reacted horribly. I had it on for about 3 days, approx 500km's of driving, and I removed it, and put the factory TCV back. Car drove much better.
I have read a lot about the CBV replacement, but I don't really like the idea of tackling that job. I expect it to be a royal PITA. Plus, I am thinking about upgrading the turbo. I have the 13g from the LPT, but I don't really have the budget right now to buy a bigger 16t, and then get a tune as well.
I saw on facebook that Lucky has a new billet 19T refurbished cold side for $600. That's interesting! But then ad an additional $400 for a tune, and suddenly my 13g seems just fine :)
Time to call Lucky at ARDideas.com for a great tune.
1 - 9 of 9 Posts
