1 - 12 of 12 Posts
02 S60 T5M - Black - KW V2, Brembos + HP5.0, FMIC, R Nordkap Swap - 128k
Selling my S60 T5 M56
I bought a GTO and my car limit I’ve agreed to with my wife is three so I need to let the S60 project go. I was planning to keep this forever but I was kidding myself as I rarely keep cars more than a year (the GTO will be car 21 in the 21 years I have been driving). Lots of work has gone in to her over the past 18 months. I have enjoyed the process and it has been a great vehicle and has never let me down. The plan was to paint it, do the 19t, and add a quaife but I want a RWD V8 platform. Everything listed has been done within the last 4000 miles using OEM or better parts and everything works as it should including cold a/c. Asking pending sale considering the necessary paint work and hoping someone will finish the project instead of parting out since it is so close to being completely restored.
Clear title and just over 131k miles
Engine/Exhaust Maintenance
Original 2.3 late 02 (stronger rotating assembly)
New timing belt, tensioner, cam, and crank seals
New accessory belt and INA tensioner
New plugs and Bosch coils
New Bosch P/S pump
05+ P/S reservoir
New fuel filter
Upper, lower, and passenger side Hutchison mounts
New Evap purge valve
New leak detection pump
Snaab FMIC + piping
IPD exhaust with custom vacuum actuated valvetronic muffler
MT90 gear oil in trans + new driver axle seal
New gas cap
New PCV system
New thermostat and upper radiator hose
Snaab cometic intake manifold gasket
Delrin shifter bushings
Suspension
Lemforder control arms and ball joints
Meyle HD sway bar links
IPD subframe inserts
IPD rear toe links
R rear stays
KW V2 Coilovers + all new febi top mounts and HW + XC90 spring seats
Alignment by IMA motorwerke (race shop)
Wheels/Brakes
Fast FC04 18x9 +40
6mm custom hub centric spacers
H&R 40mm lug bolts
Federal ST1 245/45
R Brembos cleaned and rebuilt with new piston seals and one new piston from viva (110k on calipers before rebuild)
Hawk HP 5.0 pads
Techno fit stainless lines
Brembo blank rotors
New ebrake shoes and HW
Exterior
R front bumper and rear finish panel
R side view mirrors
Interior
Premium audio speakers (except front passenger door which is a Rockford 3 way)
Nordkap R full interior (seats, carpet (steam cleaned while out of car), floor mats, door cards)
R steering wheel and airbag
R cluster cover
04+ black vents
Custom boot/knob (dyed Nordkap) setup since original spaceball was trashed.
Needs attention:
Alarm system service req code (I forgot to pull the siren the last time I had the bumper off)
Paint (or leave sleeper style)
Sunroof works but some plastics have come apart in a couple of spots
Driver side windshield sprayer clip is broken
Few broken clips (DS a pillar, rear PS step plate, DS bumper moulding, doesn’t affect function but want full disclosure)
Head unit and/or factory amp to take full advantage of premium speakers
That is it! Ready for the next adventure. Listing for well under part out value, I would just rather not undo the work I put in to it over the past 18 months. Don’t hesitate to reach out if you have any questions.
131096
131097
131098
131099
131100
131101
131102
131103
131104
131105
Where are you located?
THAT's a nice car. Essentially paint and that's it. The interior is far nicer than I imagined!
Thanks! Also, forgot to mention that three out of the four (not PS front) windows are the upgraded laminated glass. Swapped whole doors from a sapphire 04 R.
Jealous of the views and the nice porch, too!
Thanks! If I ever get around to building a garage you can use the lift for the cost of beer :)
Also, should have posted in the original. Bring your own wheels and price is 4500. How it sits on 17 inch pegs for example.
No sir, I had a guy that was potentially interested but haven’t heard anything for a few days. Somewhat negotiable on price as well.
Price and listing adjusted. Selling EST DP and extra stuff separately and putting stock cat back on.
1 - 12 of 12 Posts
