Hi All
So as I was driving along on I-95 in Philly, suddenly this ESSR light lit up !! Car doesn't experience any performance problem / no hesitation nothing as I was just driving without any problem.
Is this an early symptoms of a failing ETM / bad MAF ? I am taking the car in 2 days to my indi .. do you think it is okay to drive ..don't wanna have the car going into a Limp Mode with an 18" wheeler tailgaiting me :(
ETM has been replaced as it has the yellow sticker on it.
Any input , greatly appreciated.
Probably fine to drive. Mine was the ETM. Unfortunately I was on my way out of town when mine started throwing codes and didnt have time for an indi shop.
Probably
Your miles would help along with when the ETM was replaced
MAF, it could be anything, you need to pull codes
Thanks guys. For some weird reason, the message was gone overnight. Still going to have the indi checked it tomorrow.
JRL : Your white XC is really nice as you pulled in picking up your guest at Devon Courtyard this past weekend :)
the wheels looked perfect
Found the problem ! nothing major as the message went away.
VIDA Found ECM-9400 Brake pedal sensor signal high / intermittent fault. Decided to ignore and move on.
Thank you again for all the inputs.
