New to this forum and new to Volvo' s as well.
Actually I've had some experience with older Volvos; good friend had a couple P1800s, I owned an early 70s(?) 211 and later an eighties 4 door.
If I remember right I think the 211 had twin carbs that needed balancing every so often.
I digress. Just bought a 2001 (had reams of maintenance/servic records) V70 2.4t.
Shortly after I bought the car I drove some friends to the airport (about 40 miles, mostly freeway).
Shortly after dropping em off the cruise control quit workin and car started to vibrate, especially @lower rpms/under load and the CEL came on.
Few days later took the car to autozone and scanned for trouble codes and the printout said misfire cylinder. #1.
After a lil research I bought five new plugs and a Bosch ign coil.
Replaced the coil and plug on cylinder 1 and no change...
Took car to local repair shop and they said that I had a bad #1 coil...verified (so they say...) by swapping w/ cylinder #2.
Wife went to parts store and bought a no-name-brand coil. Installed coil and same result.
Miscellaneous trivial info:
Car seemed to run rougher while driving it home from the shop than when driving it to the shop?!! It even sounds different.
Visual inspection of wiring revealed nothing. I'm gonna find a wiring dia. ( I hope), buy a multimeter and check associated wiring.
What are the odds of receiving two bad coils?
If wiring is good would the next most likely suspect be the ECU (Computer, black box, etc.)?
Thanx in advance for any help.
Take care and stay safe
Roger
P.s. also cleaned connector and ground
Roger
