1 - 1 of 1 Posts
Alright so I picked up my first p2 v70 NA 2.4L the other day with 162k on it. The car is straight good paint good interior a few minor interior issues but nothing bad for 800$. The guy i bought it from put a lower mileage engine after the original threw a belt, he hooked up most of the stuff and then it sat for 2 years. I got it home and got it running the next day. Put a can of fresh premium in the tank to help dilute the dated gas. Car will start when cold fairly easily and idle ok but once it has warmed up the idle becomes irratic and hovers around 5-800rpm and dies periodically. Currently keep getting 3 codes P1620, p0032 and p0506. the etm is a yellow label with a date code of 2006. I have tried unplugging the 02 as well as the vvt valve with no change in idle. When warm can coerce the pedal and when it revs it revs nicely and smoothly past 1800rpm but usually takes a bit of feathering the throttle to get it to rev. When cold will idle consistanly and rev easily
1 - 1 of 1 Posts
