Im new here and a turbo novice, I have been looking for the TD04-14T with no luck, so I was thinking can I use a MBC and get more out of the 12T? I also have come across a TD04HL-13T would that be an upgrade? I am looking for any suggestions or advice on what to do. I only ask to keep it practical I'm not rich and have three kids. Thanks guys.
13t won't fit, 14Ts are around on ebay but you have to make sure you buy the right one, I run an MBC on my 01 but its a good idea to have supporting mods, exhaust intake, you'll need bigger injectors in 00 or you'll lean out
Been looking for the 14T with no avail, I did find a TD04HL-16T that in the listing says Volvo S40 upgrade, is this true? I know the 19T will work but what about the 16T? I appreciate your help and advice.
nope it won't fit, the only direct bolt on for an 00-04 is the 14t from europe, the others are compatible with the newer 04.5+ S40s, any 19T is just a 14T with a 19T wheel or a 19T for the newer S40
also with any turbo upgrade you'll still need to upgrade your injectors, FPR and at the very least a K&N drop in air filter
