Okay friends, I'm gonna need some major help if you can please. I've tried to put together a list with part numbers of everything I need for the swap before I do anything. I really really really don't want to find out I'm missing something in the middle of the process. If you guys see anything on this list that isn't needed, which I'm sure there will be, please let me know so I can update the list. Similarly if I need to add anything to the list as well. I've hyperlinked the items for quick reference if that makes it easier. Remember, I have a 1997 850R and I got the donor transmission from a 2001 C70 so it's not an 850 to 850 swap..
PARTS NEEDED:
1) M56H GOT IT
2) C70 Shifter Assembly GOT IT
3) C70 Pedals GOT IT
4) C70 Shifter Cables GOT IT
5) R Clutch and Pressure Plate - VOL-272218 $262
6a) Flywheel - 17.1 lb Billet Single Mass Flywheel - SO13S $440 (This one from Viva is 1.3 lbs lighter than stock which I would imagine means quicker revving, but the site says it might chatter slightly during idle.)
6b) Flywheel - Original Single Mass Flywheel - 9454774 or 9454772 - $470 or $390
6c) Flywheel - Original Single Mass Flywheel - Used - $100-150 (Not sure if at this price it would just be better to get a new one. I want to do this right from the beginning.)
7) Clutch Line - VOL-9181324 $77 SITE SAYS IT DOESN'T FIT 01 C70
8) Manual Throttle Cable - VOL-9157600 $45 SITE SAYS IT DOESN'T FIT 01 C70
9a) Stainless Steel Cable Bushings - CEB-850 $27
9b) Spherical Cable Bushings - Kaplhenke - $75
10) Delrin Shifter Assembly Bushings - SAB-850 $36
11) C70 Sport Shifter - 45120 $136
12) Subframe Bushings - Kaplhenke - $170
13) Rear Main Seal - NEED A LINK TO CORRECT ONE
14) Flywheel Bolts (10) - VOL-9454743 $3
15) Pressure Plate Bolts (6) - VOL-959219 $2 SITE SAYS IT DOESN'T FIT 01 C70
16) Shifter Ball Seat - VOL - 9183908 $21
17) SACHS or FTE Clutch Slave Cylinder - 31259445 $139 or $141
18) Axle Seals (2) - VOL-6843481 $10
19) Hydraulic Line O-Ring - VOL-9143918 $5
20) Quaife LSD - QDF12J $1100
DO I NEED THESE?
21) Shift Cable Retaining Bolts (4) - 3502507 $2
22) Clutch Return Spring - 9140179 $10
23) Axles
24) Master Cylinder - 9181339 $215
25) Clutch Pedal Position Sensor - VOL-9472979 $70
26) Throwout Bearing - SB60120 $48 SITE SAYS IT DOESN'T FIT 01 C70
What about reverse light? What about cruise control?
PARTS NEEDED:
1) M56H GOT IT
DO I NEED THESE?
23) Axles
