Forum Discussions about this Product
1 - 2 of 2 Posts
    1. · Registered
      Is there any potential for the wheel chair to fit into the car ? If so then the problem changes to finding a loading aid to get it into the car.
      The unbraked trailer rating for the XC60 (like many recent model vehicles) is 1650 lb. There are many light trailers that with a 500 lb. load will be well below that.
      You may be able to find a light utility trailer with a ramp. Or something with a tilting bed like this:
      But that would require at least adding a plywood floor and a way to anchor the chair. Perhaps something like this might be worth considering:
      They offer a wheel for the front which might be valuable to let you disconnect the trailer and push it around if you are in a tight spot or have trouble finding appropriate parking. This is also a more compact and possibly lighter trailer.
      There is a note that says it may not work with some mid-wheel drive chairs which suggests that any trailer that uses a ramp might have the same problem. Perhaps as you start up the ramp the drive wheel gets lifted into the air or as you come over the top the chair rocks on the middle wheel.
      If you do go the trailer route I think it is a good idea to get the wiring harness provided by Volvo. That way the car knows you have a trailer attached. I have towed light trailers with a number of Volvos over the years and seen things like automatic transmission shift patterns change when the trailer was attached. The one complication you might run into is that since they introduced the folding hitch the associated harness wants a connection to the hitch. It may be possible to get a harness for an earlier model year but getting appropriate software could be a challenge. Look for relevant posts in other threads or in the XC90 forum.
      Sent from my Pixel 6 Pro using Tapatalk
    2. · Registered
      This has been my whole problem. Findng a method to properly support her power chair off the back. The chair alone weighs 450lb, which I've since found out is 100lbs MORE than the tongue weight recommended by Volvo (even though my hitch has a 900lb TW rating). So I have sourced a trailer, one of the Harbor Freight 40x48 trailers. It has a 1000lb capacity, which is more than enough to support the power chair and way UNDER the towing capacity of the XC60. I'll put a 1/2 plywood platform over the trailer once assembled. Its a 'bolt together' trailer but I will be welding the seams for a more secure fit. I also have aluminum ramps capable of 1000lbs that I can put the chair on the trailer. I'm modfiying the underside of the trailer so the ramps will slide under it for transport. Some will 'crap on my idea' of the Harbor Freight trailer and call it junk. So far the only thing I found "Junk about it is the low quality wheel bearings. Which I will replace with better ones before I put it on the road. I think I should be fine once I understood the limitations. I'm just glad for the 3 times I took it out attached to the hitch that I got out and home safely. It could have gone bad fast.
1 - 2 of 2 Posts
Forum Reviews
Be the first to review this product
Write a Review
Do you have experience with this item? Help our community members and share your knowledge.
Sign in to add review
