Forum Discussions about this Product
1 - 3 of 3 Posts
    1. · Registered
      2005 S60 T5 M66 - 4C Deleted
      Discussion Starter · #153 ·
      I never bothered to do a writeup of how I installed my HID R Bi-Xenon retrofitted lights onto my halogen equipped car since it was such an oddball case and didn't think there would be anyone else that would run into the same issue. Well, another member ran into probably the same problem, so I posted more about it, and thought it would be good to copy it here for record keeping.
      __
      I dug up this old wiring diagrams I made. This is the plug on the car side. This plug connects to the intermediate headlight harness, that I purchased to cut up. Volvo P/N 30678832. Check your wiring colors and it would be best to check the actual pin outputs with a volt meter also. What I did was put the headlight switch into all of the different states (turn dial) and measured the output of each pin. This is what I wrote down almost 9 years ago when I first put the R retrofitted lamps on, but it could be wrong.
      On that harness, I cut the lead from the car side, pin 3 and wired it to the DC-DC Buck converter. Amazon doesn't sell the one I used anymore, but this one is close (also the same Drok brand I used) DC-DC Stabilizer 9v-36v to 12V
      The output of the buck converter, I measured to make sure it was a stable 12V when the headlights are supposed to be on. I then wired everything to an auxiliary fuse box (this is the exact one I used) 12-Slot Relay/Fuse Box and got some normal Bosch style 5 pin relays. I used these: 10pk Bosch Style 5-pin 12V Relay SPDT
      Then the output the relay gets routed back to the headlight 'input' low beams.
      I used all 5 slots of the relay box for:
      1. Left Low Beam (car side pigtail, pin 3 left side)
      2. Right Low Beam (car side pigtail, pin 3 right side)
      3. Left High Beam (car side pigtail, pin 7 left side)
      4. Right High Beam (car side pigtail, pin 7 right side)
      5. DRLs (R Lamps) (car side pigtail - one of the sides, pin 2)
      I then wired the +12V feed for the aux fuse box to the main power feed right next to the driver side front strut tower, and found a ground also close to there. I don't remember what sized wire I used, but I calculated the power draw from the headlights at max power, and used the distance. Probably 12 AWG wire.
      Here's a pretty bad picture of it that shows basically everything.
      Red Circle - Where I connected to +12V
      Black Circle - Close to where I connected to GND
      Blue Circle - You can see the aux fuse box tied down to the other hoses and wires
      Green Circles - The headlight intermediate harnesses are here
      Red Line - Running the line from one side to the other.
      The whole thing is plug and play onto the Volvo S60T5 halogen wiring harness, and the R lamps. And all the wires hide very nicely under panels, along with the fuse box itself. I made a harness with heat-proof wire sheathing and shrink wrap to protect the wires. I've been using the setup for the better part of 5 years and it has been flawless.
      For the prior 4ish years, I was running some really low quality relays that were so slow to act that the PWM signal actually didn't turn them off with the fast refresh rate. I got lucky here and ran them that way for a few years until one of the crap relays started sticking and not turning on, thus requiring me to do the whole voltage regulator + fuse box solution.
    1. · Registered
      I can confirm this. Currently have a set of Xenons from an 04 xc70. Even with the correct harness the bulb will ignite for a few seconds then shut off.
      Contacted hilton tuning and apparently they can reprogram my CEM (car came with halogen) remotely to allow the Xenons to work... For a very large amount of pennies.
      Any chance you can share some pictures of your wiring? I had pretty much given up on making these work and was planning to retrofitting projectors in there.
      Sent from my SM-G973W using Tapatalk
      I never drew up a wiring harness diagram, nor did I ever really take any pictures of the process, but these are the components I used to make it all work:
      - Any standard headlight relay harness, to grap the wires, connectors, and wire shielding/wrap from
      - secondary aux fuse box This was a nice addition as it had spots for 4+ relays and 4+ fuses to keep it all together and neat.
      - relays
      - voltage regulator
      And probably some other misc connectors, wires, odds and ends.
      I mounted the aux fuse box under the false plastic panel to the right of the air box (I have the R style air box so there is a lot of room there). Just zip tied to the loom of wires, tubes, and hoses already there.
      I used R headlights as a base and retrofitted projectors from TRS - Morimoto D2s 3.0 Square projectors with square gattling fun shrouds (PITA to trim and install). I used the R HID ballasts and LED bulbs in the DRL socket.
      I wanted to keep the OEM R HID Ballasts because they are integrated into the headlight housing, so no external wires and no holes in the housing. The back cap is already hard enough to get off and work around on the passenger side you don't need more wires there getting in the way.
      How I wired everything:
      - used a multimeter to probe every wire on the headlight aux harness to find out what every wire output from the car did.
      - large gauge power and ground to the aux fuse box with ring terminals
      - 4 different circuits:
      1. Left bi-xenon
      2. Right bi-xenon
      3. Left DRL
      4. Right DRL
      - found the low beam and drl outputs on the headlight aux wiring harnesses and bridged the two sides, using these as the relay inputs
      - used the voltage regulator on the output of the low beam to regulate the PWM signal to a constant 12V and wired this into the relay input (the regulator linked above was adjustable which just involved reading the output voltage and turning the knob.
      - wired up the high beam trigger to the bi-xenon plate mechanism
      - wired all the relay outputs to the proper power wire on each headlight for each position.
      Relatively straight forward, just took a lot of planning and a lot of time.
    1. · Registered
      Yeah I never really took pictures of anything since my application was such an oddball case.
1 - 3 of 3 Posts
Forum Reviews
Be the first to review this product
Write a Review
Do you have experience with this item? Help our community members and share your knowledge.
Sign in to add review
