Re: RICA vs IPD softloader owners weigh in (volvosince16)
I dont think anyone has had both tunes, or a chance to compare back to back, so not sure what kind of feedback you are hoping to get?
They are both good companies. You should also consider HEICO too, IMHO. Not sure why everyone forgets about their HOP???
Any of the 3 systems will work very well. As I understand it, IPD has the fattest curve and is more towards the "safe" side (relative term), and RICA provides the most peak, with HEICO somewhere in between. HEICO is the only one that is TUV approved, IIRC, FWIW.
The IPD delivery mechanism requires a laptop that you ahve to provide, and takes about 10-15 minutes or so to flash/unflash. You also have to hook the car up to a charger during the process due to current drain of having everything on during the process. Not exactly convenient, BUT the tradeoff for data logging and diagnostic capabilities (depending on which version you get).
I think the others are little self-contained boxes, and work quicker.
Also, are you going to do any other mods (post warranty)? Some tuners are more conducive to custom tune, etc. Also, check out post-sales support too.
One last thing; none of these (AFAIK) are truly "invisible" from a warranty standpoint. If Volvo wants to look deep enough, they will find tracks...
