Re: (PornSStar)
Quote, originally posted by PornSStar » |
I don't understand why you don't get the konis or bilstien for our cars? that is 3 different setups plus the heico variant and the Evolve? |
Because they are all 1500 dollar plus coil over systems. I want just improved shocks and struts and different springs. I don't want my car to bounce after just putting lowering springs on stock shocks because of the diffrent spring rates and shock valving of the stock shocks.
Most people here lower for looks. I am lowering for performance. I auto cross and the stock height and soft springs are not my preferred set up.
Mazda speed 3 Springs shocks and struts fit our cars, and the MS3 is unbeatable
Not to mention coil overs put me into a different class where as a stock spring and shock do not.
I cant also see a reason for me to buy coil overs, I don't need to actively raise and lower my car. I live in FL and we don't encounter snow, gravel ect. Like I assume you would up north where you may want that height adjustment.
Like I stated I don't just want to put springs on stock shocks, and have my car bounce around after every speed bump. I was a WHOLE set up. Unless some one sells struts and shocks for our cars, Im going with speed3 suspention.
Not to mention I can get the whole thing for 200 bux.
