This is for Volvo techs or any tech doing pistons and rings. Here is another way to set up the balance shaft timing. You may or may not be aware of this. Instead of setting up and using the dial indicator gauge. Push the balance shaft all the way back. Bolt the lifting eye against the balance shaft. Insert a .75 mm feeler gauge between the 2 and tighten the balance shaft assembly. All done timing is set.
