My calculations = 2.5 % per year for the past 6.25 years.
How about yours?
Sent from my SM-N986W using Tapatalk
How about yours?
Based on historic charge activities. In the end of 2019, I was able to charge to ~7.16 kWh (best) from "zero" capacity available. Today, I can only charge to ~6.46 kWh (best) within 3 hours.Based on...?
I did the math a bit different, assuming everything you provided is correct, it is more like losing 3.3%/year of what you have left, not 2.5% of total. Your way, battery will be useless after 40 years, and 50% after 20 years.Based on historic charge activities. In the end of 2019, I was able to charge to ~7.16 kWh (best) from "zero" capacity available. Today, I can only charge to ~6.46 kWh (best) within 3 hours.
7.16 - 6.46 = 0.7 KWh
0.7 / 7.16 = 9.776 %
9.776% / 2.5 years = 3.9 % per year.
Based on the range I estimated:
In 2016 (March), I could get 32 km range.
In 2022 (July), I can get 27 km range.
32 - 27 = 5 km
5 / 32 = 15.625 %
15.625 % / 6.25 years = 2.5 % per year.
Total Charge (only from home charger):
I expect more range lose in the future.
you get 27 km real distance or this is shown on the dashboard? i get 20 km net and 5kw usable capacity (xc90 t8 16)In 2016 (March), I could get 32 km range.
Yes, 27km on the dashboard with pure mode.you get 27 km real distance or this is shown on the dashboard? i get 20 km net and 5kw usable capacity (xc90 t8 16)
How do you count the charge cycles? I only get charge counts.Typically, battery capacity degradation is measured against charge cycle count rather than time. If you can access cycle count, that would be a better metric for this survey
For those who are interested, this is because lithium dendrites on the anode (and other cell artifacts) form primarily as ions are exchanged, rather than when the battery is in stasis.
In my previous vehicle, I lost 6% capacity after approximately 250 charge cycles (over 36 months and 50.5k miles).
OK I get 32km but in the first 3 kms are dropping fast to 24km and as real distance I get 21 kmYes, 27km on the dashboard with pure mode.
It depends on how you drive. When was your last total software update?OK I get 32km but in the first 3 kms are dropping fast to 24km and as real distance I get 21 km
My last total software update was two weeks ago. The dealer did this when I took it in for this problem. They returned it that time saying it was working as designed. I tested after and still had just 10 mile range.It depends on how you drive. When was your last total software update?
Numerous T8s had a BECM issues, which could be part of the problem. My T8 slowly began showing 15 miles of range in PURE (down from 20) and a BECM firmware update and reset fixed it.My last total software update was two weeks ago. The dealer did this when I took it in for this problem. They returned it that time saying it was working as designed. I tested after and still had just 10 mile range.
Probably the same thing. I don't have a T8 (yet), so I don't know how you arrive at that number in this vehicle.How do you count the charge cycles? I only get charge counts.
