I wash and dry the car, use the prescribed "lube", and the clay smears and leaves white clay residue on the panel? Its a bugger to get off!
What am I doing wrong?
Quote, originally posted by chinaonnitrous1 » |
Use more lube? |
Quote, originally posted by mike_c70 » |
Are you putting pressure on to the clay? You only need to put "very little" if any, the clay needs to glide over the surface to do it's job. |
Quote, originally posted by nobbe3728 » |
The problem is you need to clay the car with it still wet....rinse the soap off, then clay it...use the "lube" too |
Quote, originally posted by Needsdecaf » |
Don't do that. Water has contaminants in it that you will spread around. Sure, you use less lube, but this isn't what you want to do. Start with a DRY car, and use plenty of spray. |
