Just recently my 2009 Volvo S60 2.5t fwd started going into "Reduced Engine Performance" and would clear up with a reset but unfortunately it persisted and I was able the last time it occured to limp into a O'Reilly's and get it scanned which gave me the stuck throttle position code. After hearing that and the rep continuing after reset I started the car with the pedal depressed and was able to go on my merry way. Only thing is now I have a check engine light which I had read and it came out to be p-2135-9200. I recently cleaned the throttle body 5-6 months prior and used dielectric grease on the sensors so I was wondering what solutions you guys might have for me. I was gonna take it apart today but I thought I should get some opinions before I dive in and end up not fixing the problem.
Thank you guys very much
