You cant post a sexy tire and not give some type of review on it... Thanks for the delayed edit
Ok, so....
Dry weather - great tire. Very firm ride, stiff sidewall. Noise overall is pretty good. Great grip on asphalt, concrete not so much.
Cold weather - ok tire, it needs to be warmed up. Don't drive hard until you do.
Wet - Decent, Hydroplaning was an wasn't an issue. In the volvo it had no issues but the Rx7 it did glide an lane shift from time to time WHEN I had the downforce on low. When I had the downforce on high I could do 70+ plus in the rain no problem.
Damp/slick - Horrid tire, almost dry skip when thrown into anything other then a straight line.
Wear - Ok depending on how you drive.
These where my favorite tire to do burnouts in, NOT DRIFTING. Drifting these were the scariest thing known to man and I know this because I had them on two opposites as far as Psychics in automobile chassis goes. On the Awd 4000lb tank they were good with dry an would dry slide if pressed hard enough (VERY hard). The Rx7 though was a different ball game, 95 inch wheel base (which already means terrifying slides), RWD, 2680 total weight and 350+ Rwhp.
The car regardless could break almost anything lose but as I said earlier these just let go, there's no ease into the slide, no gradual degradation of grip... they just pull the road out from under you and are just as tacky when trying to regain grip after breaking it loose. After sliding with those in the Rx7 I realized I needed a more forgiving tire being that the chassis wasn't. Lamens terms, the shorter the wheelbase the more violently the car tries to correct itself (swings) an thus in a long sedan it's much easier to correct then a low light weight sports car. They are cool tires though...
Also had the proxie 4 \/, basically the same except a bit softer, easier to slide and better rain performance. Not as good dry though.
