So im looking to upgrade the turbo on a volvo 850 t5 wagon. Whats the best turbo to get for this?
The 98 v70r comes with a 16t stock just FYI. The 16t Definetly spools faster but my feeling is the 16t with a tune performs stronger on the highway. This is my personal experience so I prefer the 18t in our big Utah highway mountain passes where it's helpful/needed.All HPT 850's received TD04HL-15G turbos, with stock boost for turbo and T5 models set at 9.6 psi, and T5-R and R models at 10.5 psi (stock hp are 222 and 240, respectively). (The European 850R received a 16T turbo)
All HPT 70-series cars received 16T turbos (with the exception of the V70R's, which received 18T's in 98 and 99, and 19T's in 2000). Not sure on stock boost setting, I'd assume it's around 10 for the T5's and probably 12.5 or so for the R's.
see I beg to differ. #1 16T is dirt cheap anyways, $100 for a decent turbo and you rebuild it yourself for another $50. #2 with going to the 16T you don't have to "baby" the car. like you do with an 18T or bigger turbo. Hell you don't even have to get a Tune for it unless your going to up the PSI. #3 for CITY driving 0-25 mph is a big deal. If I can't pull out into traffic because I'm waiting for 25mph for the turbo to spool im gonna be screwed.Unless you can get it dirt cheap or already have one, going up to a 16t from a 15g is a waste of time and money. You'll barely notice anything. 18/19t, ard blue tune, 3 inch dp. Auto will be fine as long as you keep healthy fluid and don't beat it like a dog. Might also be a good idea to invest in an external trans cooler although I don't have one and have had zero issues. You'll be noticeably faster than any 15g/16t car. The tiny loss in low end torque really isn't even enough to be mentioned. Your car will pull much harder from 25 and up. Wheel spin isn't a good thing anyway.
Although not a direct bolt on, the k24 is becoming a more common upgrade. But even with an external cooler you're probably really reaching the trannys limits. Might be a bad idea unless you're planning on doing a manual swap in the near future.
I'm sure it did feel faster. I've never driven a car with a 16t so you shouldn't even listen to mewell I think it also depends on which 15G they have. My 95 was a conical flange, and as soon as I went to the 16T I noticed a BIG difference. I could have gone with a 15G and just changed the Flange and your statement would probably be true... not much of a difference.
