01 S60 T5: RICA vs IPD
6.5K views 18 replies 10 participants last post by  Volvofool
ME7 is a type of ECU you have on your s60. And in one of the threads i've seen Lucky mentioned that he is tuning 2001 cars now. Also i don't think that softloader is utilized.
But you should better contact the man himself for all the questions
I know I'm in the wrong forum here, but I second the idea of waiting for ARD. Lucky's products/tunes are top notch and competitively priced. Use a little patience and you'll be rewarded greatly.
While you're waiting, pick up his lightweight crank pulley for your T5
Lucky will have 4 ways to tune your car.
1. Send him your ECU, and he tunes it, or he can clone it, and you can have your stock tune, and a second ECU with the tune in it, you supply the spare ECU.
2. Buy the cable and tune from him for $695, and he can email you tunes.
3. Go to SNAAB, Kristian is a dealer for Lucky
4. He can custom tune your ECU at $75/hr, but that usually means dyno tuning.
I have a RICA Stage 2, and he has looked at the tune (he pulled my tune to get the manual code for the tunes) and he showed me where he would probably change it slightly from what they did. Not necessarily better, but different, and he takes more care in making certain that interdependent parts of the tune are in sync for everything, whereas RICA, and the others don't go quite that far. Tune works great, but he does just a bit more. Will tune for DP, SNAAB intake, bigger turbo, different injectors, etc.
My stage III has about 7 years and not a single problem
#18 ·
Need to watch the Volvospeed Performance section, ARD Tune ME7 posts. Lucky just announced that he will be able to include about 3 maps in the ECU, and it can be controlled from the turn signal stalk!
See post #111
http://volvospeed.com/vs_forum/topic/151580-ard-tune-me7/page__st__100
I think that when he implements that, ksimp88 will have all that he wants.
