Hey guys,
When attempting to change my wheels from winter to summer, my mechanic noticed a lot of play in the front left wheel. On closer inspection the bottom coil of the spring had cracked right off.
I put these springs on about 4 years ago, bought them from EuroSportTuning along with Koni FSD. This is a little odd considering that the spring isn't very long.
Does Eibach warranty against this? If I swap it out, can I get by with just one spring, just the fronts, or do all 4 have to be changed? Can you even by springs in less than a quantity of 4?
Any input would be appreciated. Thanks guys.
