Decided to paint my amaltheas semi-gloss white
success!
Yes that would be ideal. Good luck!Fingers crossed. I hope I am done worrying.
Glad the dressing tips worked out!Thanks. On a related note I did find tire sponge applicators as someone suggested. I sprayed the foam onto the sponge and carefully applied dressing to each tire after a wash this past weekend. Went slowly and light this first time and so far it has worked out well. FAR less brake and road dust on wheels almost five days in. May apply more to get it shinier this weekend. Hoping to get a coat of wax on. Anyone use pinnacle? I love it. I apply with my fingers. No pad to scratch the finish and ground stuff in.
Thank you! And you're right about the roads here, they're not easy on the cars here. But that would be awesome! I'm sure they won't hold up as long as I would like lolNice car! It's clean.
If you're interested, I have a set of FSD's that I previously had on my 01' T5 that aren't being used. I ended up switching to Bilstein with my Eibach Pro kit. They're already installed into the oem housings per the koni instructions, one rear is leaking a bit, otherwise they ride great. I'd give em away if you want them for spare use, i'm sure roads in Maine aren't as forgiving as here in Atlanta.
I can tell you one of the best upgrades on my vehicle is the 15mm spacers i'm running. The wider track makes the car very neutral through hot corners and it has less brake dive and lift on throttle. Just stays flat and pulls..Thank you! And you're right about the roads here, they're not easy on the cars here. But that would be awesome! I'm sure they won't hold up as long as I would like lol
They are the tirerack ones so I'll probably have to invest in some spacers. Sounds like a good upgrade.I can tell you one of the best upgrades on my vehicle is the 15mm spacers i'm running. The wider track makes the car very neutral through hot corners and it has less brake dive and lift on throttle. Just stays flat and pulls..
what offset are those wheels? if they're the tirerack ones it's 46mm, so they'll sit very flush to tucked with the fsd kit.
